Thermally stimulated current in SiO2
2007/07/02   下载量: 38
方案下载
应用领域
检测样本
检测项目
参考标准
Thermally stimulated current (TSC) techniques provide information about oxide-trap charge densities and energy distributions in MOS (metal-oxide-semiconductor) capacitors exposed to ionizing radiation or high-®eld stress that is dicult or impossible to obtain via standard capacitance±voltage or current±voltage techniques. The precision and reproducibility of measurements through repeated irradiation/TSC cycles on a single capacitor is demonstrated with a radiation-hardened oxide, and small sample-to-sample variations are observed. A small increase in E0d center density may occur in some non-radiation-hardened oxides during repeated irradiation/TSC measurement cycles. The importance of choosing an appropriate bias to obtain accurate measurements of trapped charge densities and energy distributions is emphasized. A 10 nm deposited oxide with no subsequent annealing above 4008C shows a di€erent trapped-hole energy distribution than thermally grown oxides, but a similar distribution to thermal oxides is found for deposited oxides annealed at higher temperatures. Charge neutralization during switched-bias irradiation is found to occur both because of hole-electron annihilation and increased electron trapping in the near-interfacial SiO2. Limitations in applying TSC to oxides thinner than 05 nm are discussed.
方案下载
上一篇 STA表征硫化橡胶组分含量
下一篇 药物赋性剂研究
文献贡献者
相关方案
当前位置: 塞塔拉姆SETARAM 方案 Thermally stimulated current in SiO2
