方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Concentrations of ammonia and copper can be determined successively by following procedure:Ammonia is titrated first with sulfuric acid solution. On completion of the first tiration, potassium iodide solution is successively added, and rebated iodine is titrated with sodium tiosulfate solution based on redox titration. The obtained result from the second titration indicates the amount of copper contained in the sample.
最新《饮用水安全检测解决方案》解决方案
最新《饲料产品检测解决方案》解决方案
最新《食品安全检测解决方案》解决方案
