资料下载Series STM 10 / 20 kN The test is conducted to determine the strength of the bond between the spray deposit and the parent material (adhesive strength) and/or the strength of the coating (cohesive strength). It is qualified for coating thickness over 150 µm. The test is used to evaluate the effects of parent material and spray material, surface preparation of the work piece before spraying, and the spraying conditions on the adhesive strength of thermally sprayed coatings, or for quality control and routine supervision of the spray works. Shear Testing Machines according to the new European Standard EN 15340 Standard was developed within a European Joint Research Project together with: Fraunhofer Institut IFAM, Bremen EMPA - Materials Science & Technology walter+bai ag - Testing Machines The Shear Testing Machine Series STM in accordance with ISO 7500-1 allows tests corresponding to new standard EN 15340 with the required accuracy and reproducibility. The high precision sample holder guarantees an exact fixation and alignment of the specimen without any movement of the sample during the shear test. The shear plate is made of carbide and fixed close to the high precision load cell for best results. It allows a movement during loading in the guide ways without deviations or friction that affects the measured shear force. The edge of the shear plate is parallel to the interface coating/substrate and parallel to the upper face of the sample. Thus a uniform loading of the coating is ensured. Worn out carbide cutting plates can be changed very easy. Evaluation: The shear load resistance is taken from the first maximum of the force displacement curve. To clearly distinguish between cohesive and adhesive fracture of the coating it is advisable to evaluate the fracture interface by means of a stereo microscopy (option). Test Reports: Using of the optional Shear Test Software it allows to print test reports in accordance with standard EN 15340 containing: inspection body, inspector, date, coating thickness, shear distance, thrust velocity, type of fracture, particularities, remarks etc.
化学钢化玻璃的抗划性能应用报告
简介:自2008年康宁®大猩猩®玻璃问世以来,一直被用作智 能手机屏幕。 2020年Victus®版本的大猩猩®玻璃的发布显示出,这 类材料的开发仍需持续不断的努力。 研发具有抗划和抗冲击性能并可以保护智能手机的钢 化玻璃是非常重要的。这类玻璃需具备足够的表面强 度、控制缺陷和抗划伤能力。 除消费类电子产品外,化学钢化玻璃还应用于工业、 汽车、航空、建筑和制药等领域。
钢化玻璃手机膜耐磨性能测试应用报告
简介:在报告中,SMT-5000对智能手机的钢化玻璃屏幕进行 抗划性能测试。SMT-5000也可以通过遵循ASTMG133或 其他相关标准,对钢化玻璃进行摩擦磨损测试,以进 一步分析和研究此类材料。 在不同时间间隔采集的图像提供了材料失效过程的信 息。通过共焦图像,可以计算体积和面积,简化了分 析过程。 尽管这三种不同的屏保声称具有相似的性能,划痕测 试可清晰分辨样品耐磨性能和抗断裂性能的差异。
电化学的原理及应用
简介:本文简要的介绍了关于电化学工作站的主要组成和相关原理,总结了近几年有关电极测试和修饰方面的方法和技术,结果发现,由于汞的污染性和汞膜镀电极的不灵敏性,目前对于汞膜镀电极的研究越来越少,对于铋膜和锑膜镀电极的研究较多,而且电极重现性及灵敏度都相对较高。另外,运用电化学工作站体系测试方便简洁,成本较低,并适合多项研究和实际应用。
低温技术及其应用
简介:低温技术不仅与人们当代高质量生活息息相关,同时与世界上许多尖端科学研究(诸如超导电技术、航天与航空技术、高能物理、受控热核聚变、远红外探测、精密电磁计量、生物学和生命科学等)密不可分。在超低温条件下,物质的特性会出现奇妙的变化:空气变成了液体或固体;生物细胞或组织可以长期贮存而不死亡;导体的电阻消失了——超导电现象而磁力线不能穿过超导体——完全抗磁现象;液体氦的黏滞性几乎为零——超流现象,而导热性能比高纯铜还好。下面我将主要介绍低温奇迹、低温技术的应用和低温是如何产生的。
MEMS材料力学性能测试方法
简介:随着机电系统(MEMS)的蓬勃发展,如何准确获得MEMS 材料力学性能参数成为当今研究的热点。由于尺度微小,试样的夹持、载荷的施加和测量、位移的测量等问题十分突出。本文对当今MEMS力学性能研究中一些典型的微测试方法,如纳米压痕法,单轴拉伸法、鼓膜法、微梁弯曲法及衬底曲率法等分别进行了阐述,详细介绍了这些方法的原理、优缺点以及可测得的力学性能参数。
