交流阻抗RC串联图
简介:RST5200仪器在使用过程中评定等效电路,测试电子元件数据的保存依据。 了解简单电极反应的等效电路。 了解交流阻抗复平面图和波特图的意义。
Determination of Trace Manganese by Squa
简介:Determination of Trace Manganese by Square-Wave Stripping Voltammetry Shujie Wang, Baoxian Ye* Department of Chemistry, Zhengzhou University, Zhengzhou 450052, P. R. China *e-mail: yebx@zzu.edu.cn Received: August 6, 2007 Accepted: January 9, 2008 Abstract A novel method of determining trace manganese by square-wave stripping voltammetry with simultaneous plating mercury electrode is described in this paper. Well-defined stripping peaks of manganese are obtained in H3BO4- NaOH buffer (pH 8.0) and peak currents are in good linear relationship with manganese concentrations in two ranges: from 0.36 nM to 36 nM and from 73 nM to 909 nM. The obtained detection limit is 0.18 nM and relative standard deviation is 2.3% (n¼;;;;7) under a predeposition time of 90 s. This proposed method has been used for the determination of trace manganese in real plasma samples with satisfiable results and good matching with the results of graphite furnace atomic absorption spectrometry. Keywords: Manganese, Square-wave stripping voltammetry, H3BO4-NaOH buffer, Plasma samples DOI: 10.1002/elan.200704136
售后服务承诺
简介:1..本公司产品不论国内哪家公司经销,都有本公司负责派人安装调试,安装调试完成后双方签订验收单.和售后服务承诺书,仪器出现问题直接电告我公司进行售后服务。 2.仪器自签订验收单之日起三个月内发生质量问题,我公司负责调换新的同型号仪器。仪器售出一年内发生使用和质量问题,我公司负责免费维修。 3..三年内仪器出现问题,只收象征性费用,仪器实行终身维修制。 .人为损坏不保修。
RST3000系列电化学工作站使用说明书
简介:本工作站是由RST公司在原有基础上改进的新一代产品,具有完全自主知识产权的电化学分析仪器。本手册介绍了RST3000系列电化学工作站的安装使用方法和操作时的注意事项。请在使用前认真阅读。
反应釜
简介:本水热合成釜采用型号为316L的优质不锈钢加工而成。釜体与釜盖密封采用耐用、可靠的线密封结构,内套为聚四氟乙烯材料加工制成,密封效果长期稳定无泄漏。 釜盖采用螺旋紧固结构设置、并辅以釜体定位装置,以利合成釜的开启与密闭。 本水热合成釜采用外加热方式,以缩小体积,并有利多反应釜处于同一反应操作温度(如将多个反应釜置于烘箱中加热)。
