方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
在本文中,我们评估市售的生命时间为基础的光学探头的性能,并与其他方法获得的数据进行比较。 针对不同水质,包括浅海水、污水、深海水等,一共做了11个不同的实验,包括对比目标实验室值、和现场研究。得出的结论是,这种方法,由于精度高(± 2um),长期稳定的(超过2个月);不受污染物的影响,没有压力的滞后和交叉灵敏度限制,比其他方法更适合长期稳定监测溶解氧。 In this paper we evaluate the performance of a commercially available life-time based optode and compare it with data obtained with other methods. A set of 11 different tests including targeted laboratory evaluations and field studies were performed covering a wide range of situations from shallow coastal waters and waste water treatment plants to abyssal depths. The principal conclusion reached is that this method, due to high accuracy (±2 μM); long-term stability (more than 20 months); lower fouling sensitivity; no pressure hysteresis and limited cross sensitivity, is overall more suitable for oxygen monitoring than other methods.
