方案下载应用领域 | 医疗/卫生 |
检测样本 | 其他 |
检测项目 | 生化检验>无机物质及血气分析 |
参考标准 | 暂无 |
From each patient one biopsy was thawed. The thawed tissue was cut into two comparable parts and the wet weight of both parts was measured. Both parts were dried overnight at 100?C, after which they were weighed again in order to measure dry weights. One part was dissolved in nitric acid and consequentially diluted, and sodium content of this solution was measured by way of flame spectrometry. The other part was ashed to measure nitrogen via thermal conduction (Dumatherm Nitrogen/Protein analyzer, C. Gerhardt). Nitrogen content of the ashed biopsies was measured as a parameter for protein content of the tissue. This protein content was used to correct for subcutaneous fat, since the assumption was that sodium is stored in skin instead of in fat, and protein is largely absent from fat tissue. Sodium content of the skin is expressed as mmol sodium per mg dry weight or per mg protein. 从每个患者中解冻一个活检。将解冻的组织切割成两个可比较的部分,并测量两个部分的湿重。两个部分在100摄氏度干燥过夜,之后再次称重以测量干重。将一部分溶解在硝酸中并随后稀释,并且通过火焰光谱法测量该溶液的钠含量。另一部分用于通过热传导测量氮(格哈特公司 杜马森Dumatherm燃烧法全自动氮/蛋白质测定仪)。测量灰化后的活检的氮含量作为组织蛋白质含量的参数。这种蛋白质含量用于皮下脂肪,因为假设钠储存在皮肤中而不是脂肪中,并且脂肪组织中基本上不存在蛋白质。皮肤的钠含量表示为每mg干重或每mg蛋白质的mmol钠。
The development of ICU-acquired sodium disturbances is not fully understood. Alterations in non-osmotic skin sodium storage, hypothetically inflammation-driven, could play a role. To investigate this in critically ill patients we conducted a patient-control study with skin punch biopsies in patients with sepsis (n = 15), after coronary artery bypass grafting (CABG, n = 15) and undergoing total hip arthroplasty (THA-controls, n = 15) respectively, together representing a range in severity of systemic inflammation. Biopsies were taken within 24 hours (sepsis) and within 2 hours (CABG) after ICU-admission, and prior to arthroplasty. Biopsies were analysed for sodium content. In addition immunostainings and quantitative real time PCR were performed. The primary aim of this study was to detect possible differences in amounts of cutaneous sodium. The secondary aims were to quantify inflammation and lymphangiogenesis with concomitant markers. The highest amounts of both water and sodium were found in patients with sepsis, with slightly lower values after CABG and the lowest amounts in THA-controls. Correlation between water and sodium was 0.5 (p<0.01). In skin biopsies in all groups comparable amounts of macrophages, T-cells and lymph vessels were found. In all groups comparable expression of inflammation markers were found. However, higher mRNA transcript expression levels of markers of lymphangiogenesis were found in patients with sepsis and after CABG. The conjoint accumulation of water and sodium points towards oedema formation. However, the correlation coefficient of 0.5 leaves room for alternative explanations, including non-osmotic sodium storage. No signs of dermal inflammation were found, but upregulation of markers of lymphangiogenesis could indicate future lymphangiogenesis.
ICU获得的钠紊乱的发展尚未完全了解。非渗透皮肤钠储存的变化,假设是炎症驱动的,可能起作用。为了在危重患者中研究这一点,我们分别对脓毒症患者(n=15),冠状动脉旁路移植(CABG,n=15)和进行全髋关节成形术(THA对照,n=15)进行了皮肤穿刺活检的患者对照研究,共同代表全身炎症严重程度的范围。在ICU入院后24小时内(败血症)和2小时内(CABG)以及关节成形术前进行活检。活检分析钠含量。此外,进行免疫染色和定量实时PCR。本研究的主要目的是检测皮肤钠量的可能差异。次要目的是用伴随标志物量化炎症和淋巴管生成。在脓毒症患者中发现水和钠的最高量,CABG后值略低,THA对照中的最低量。水与钠的相关性为0.5(p<0.01)。在滑雪
工业园区污水及经生物反应器处理后的污水氨氮、有机氮及化学需氧量(COD)的测定
使用格哈特凯氏定氮仪测定药用汉麻(大麻)中氮含量
使用格哈特凯氏定氮仪测定水溶性复合氮磷肥料NPF中氮含量
