方案下载应用领域 | 农/林/牧/渔 |
检测样本 | 家禽 |
检测项目 | |
参考标准 | GB∕T 6432-2018 饲料中粗蛋白的测定 凯氏定氮法 |
低温干燥对肉鸡和去盲肠蛋鸡排泄物中含氮化合物和肌醇磷酸的影响Effect of low‐temperature drying on the nitrogenous compounds and inositol phosphates in broiler chickens and cecectomized laying hen excreta 总氮基于凯氏法使用格哈特Gerhardt公司Vapodest 50s全自动凯氏定氮仪测定 氨氮使用使用格哈特Gerhardt公司Vapodest 50全自动蒸馏滴定凯氏定氮仪测定 Total N and ammonia in excreta were measured without further processing. For all other analyses, the excreta were freeze dried and ground to a powder using a vibrating disc mill (Fritsch Pulverisette 9; Fritsch GmbH). Kjeldahl digestion was performed on the Vapodest 50S analysis system (C. Gerhardt GmbH & Co. KG). Ammonia was measured by steam distillation and titration by using the Vapodest 50 analysis system (C. Gerhardt GmbH & Co. KG) as described by Hofmann et al. (2019). The official methods for nutrient analyses in Germany (Verband Deutscher Landwirtschaftlicher Untersuchungs- und Forschungsanstalten 2007) were followed for dry matter (no. 3.1), total N (no. 4.1.1), crude ash (no. 8.1), crude fat (no. 5.1.1) and crude fiber (no. 6.1.1) content of the diets. The diets were ground in a centrifugal mill and passed through a 0.5 mm sieve (Retsch GmbH, Hann, Germany) prior to analyses.
凯氏定氮催化剂5.0g K2SO4+0.5g CuSO4 x 5H2O
型号:KJELCAT-tablets, tin of 1,000 pcs 5.0g K2SO4+0.5g CuSO4x5H2O低温干燥对肉鸡和去盲肠蛋鸡排泄物中含氮化合物和肌醇磷酸的影响Effect of low‐temperature drying on the nitrogenous compounds and inositol phosphates in broiler chickens and cecectomized laying hen excreta
Vapodest 50已被Vapodest 50s替代,Vapodest 50s又被Vapodest 500替代。
牛奶-燕麦牛奶为基础的开菲尔酸乳酒中蛋白质的测定
盐漠大麦籽中蛋白质的测定
麻风树籽压榨分离蛋白、麻风树脱油压榨分离蛋白中蛋白质及蛋白质溶解度的测定
