资料下载以八甲基环四硅氧烷( D4 )作为模型单体, 分别使用高速分散机、超声波仪和高压均质机制备了D4细乳液,使用多重光散射稳定性分析仪(M LS)分析比较了不同方法制备的D4细乳液的稳定性, 并通过稳定性的分析, 研究了均质压力和乳化剂浓度对单体细乳液的稳定性的影响。结果表明, 在同样的乳化剂浓度下采用高压均质机制备的细乳液稳定性最好, 能够稳定进行细乳液聚合; 随着均质压力( 10~ 110M Pa) 增大, D4细乳液的稳定性先增强后减弱, 在90MPa下制备的细乳液稳定性最好, 乳液粒径增长速率仅为0􀀁342 nm /m in; 随着DBSA 浓度( 0􀀁0092~0􀀁0460m o l/L)增大, 在相同均质条件下( 90M Pa下均质4次) 制备的单体细乳液稳定性增强, 粒径增长速率都小于0􀀁505 nm /m in, 具有较好的稳定性。
如何实现对低粘度流体进行高精度测量
简介:Analyzing highly liquid products such as vaccines or water-based formulations is a delicate matter as traditional techniques are insensitive to low viscosities. Fluidicam technology allows for fast and precise measurements even for low viscosity products with minimal sample volume.
多重光散射仪在药物制剂中的应用
简介:The world of drug delivery is getting every day more efficient with new product forms, which are directly targeting the deficient organs. Colloidal systems such as emulsions (simple or multiple) or nanoparticle suspensions are now widely used as drug carriers or nutritional solutions in this respect. These new product forms allow better targeting and assimilation for the patient, and give rise to new solutions for drug designers. However, the stability of these inherently unstable colloidal systems makes them complex to formulate and study.
多重光散射仪在石油领域中的应用
简介:Asphaltenes are causing major problems in the extraction process of crude oil as they can lead to fouling & clogging in pipes or even in the entire well when they aggregate. Moreover asphaltenes play the role of natural emulsifier which stabilises water-in-oil emulsions formed during production of crude oil. Asphaltenes also have an impact on the refinery efficiency and the fuel oil quality. To overcome these technical issues, chemical additives are used. It is therefore important to have a technique that can identify the most suitable additive, but also to measure accurately the stability of oil or emulsions
多重光散射仪在食品/化妆品领域中的应用
简介:介绍多重光散射仪/稳定性分析仪在食品化妆品行业中的应用概况,该仪器适用于研发、质量控制、工艺优化等阶段,可用于分析所有液态分散体系的物理不稳定现象。
Gelling of an emulsion
简介:Gelling can be obtained through two main mechanisms: creation of a network due to a reticulation of polymers (it is the case for gelatin) or aggregation of particles (it is the case in yogurt). In the cosmetics industry it is commonly used to get various textures.
