方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The ASB-W-020 is a complete light source assembly with a tungsten-halogen lamp that emits in the 300 to 2500 nanometer (nm) wavelength region. It has been designed to transfer the maximum possible illumination to a variety of fibers. The tungsten-halogen lamp of the ASB-W-020 is a near blackbody source of light with a built-in fused silica lens that focuses the light to the fiber. Figure 1 shows blackbody spectral distributions at various color temperatures in Kelvin (K). The ASB-W-020 spectral distributions resemble those of Figure 1 out to about 2500nm, beyond which the transmission of the fused silica lens limits the output. In addition to the 20 Watt tungsten-halogen lamp (SP # ASB-W-020B), the ASB-W-020 features a lamp housing and a current regulator to assure a stable output. The housing contains an adjustable lamp mount. A variety of flanges allow the mounting of different fiber terminations, from a single fiber to bundles. The 20 Watt tungsten-halogen lamp used in the ASB-W-020 has a nominal color temperature of 3100 K and the regulated power input assures an average life of 2000 hours. The power supply provided with the ASB-W-020 is a wall plug-in type. The power supply provided with the ASB-W-020 is a wall plug-in type. Feature Value Lamp: Tungsten-halogen Power: Wall transformer, 120 VAC, 50/60 Hz to 24 VDC at 2.0 amps. 220 VAC version available Current Regulation: Built-in, ± 0.4% Color Temperature: 3100°K Bulb Life: 2,000 hrs. average (nominal) Spectral Distribution: Near blackbody (see Figure 1) Housing: Aluminum, forced air cooled, Limited focus adjustment Connector: SMA Fiber connector Options: Spare lamp ASB-W-020B Mounting flange for 10mm fiber bundle Optical bench mounts Specify FC, ST or CS for specific fiber couplers. Warranty: One year
德国Qioptiq半导体激光器助力生命科学仪器研究
数字全息显微镜DHM检测分析MEMS陀螺仪谐振频率
量子通信波段论文及资料
红外连续可调OPO激光器 德国 Qioptiq
Phasics波前探测器SID4
FROG超短脉冲测量仪+自相关仪+Swamp optics+8-20-USB
Energetiq 激光驱动白光光源LDLS EQ-99XFC
红外相机
Onefive Katana 通用型脉冲激光器
Onefive Origami 低噪声孤子飞秒光纤激光器
美国electrophysics公司 红外相机 7290A
Lyncee 数字全息显微镜 DHM R2100
electrophysics 红外热像仪 ATOM80
OKO N50mm 37/79/109通道压电变形镜(PDM)
Beam Analyzer光束质量分析仪
中红外光谱仪
光纤激光器
光纤放大器
