方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Terahertz (THz) radiation is located in the spectral region ~0.1-10 THz (~3 mm - 30 μm, 3 cm-1 - 300 cm-1) between the microwave and mid infrared range of the electromagnetic spectrum. In comparison with visible or infrared waves, THz radiation can penetrate into organic materials such as skin, plastics, cloth, or paper products. Because of low photon energy involved, it does not cause any damage associated with ionizing radiation ( e.g. X-rays). THz waves do not penetrate into metals. These properties can be used in process (e.g. drugs manufacturing) and quality control as well as in THz imaging. It is also of great current interest for such applications as safety control, packaging inspection, semiconductor characterization, chemical composition analysis, and biomedical investigations, with great promise for spectroscopy, defense imaging, and security applications. Traditionally for THz applications we use High Resistivity Float Zone Silicon (HRFZ-Si) as it is the most investigated substance for operating within this range and has a good transmission performance. In parallel with this material we have been investigating other materials which also can be utilized in THz range. Below you can see transmission spectra and other characteristics of materials we use for THz optics production. Measurements in THz region were made at ABB FTIR spectrometer Bomem DA3 and Bruker IFS 125HR (measure of inaccuracy is 2-3% below 100 μm and 4-5% over 100 μm). Measurements in near infrared range were made at Perkin Elmer “Lambda- 9” (measure of inaccuracy < 0.5%).
德国Qioptiq半导体激光器助力生命科学仪器研究
数字全息显微镜DHM检测分析MEMS陀螺仪谐振频率
量子通信波段论文及资料
红外连续可调OPO激光器 德国 Qioptiq
Phasics波前探测器SID4
FROG超短脉冲测量仪+自相关仪+Swamp optics+8-20-USB
Energetiq 激光驱动白光光源LDLS EQ-99XFC
红外相机
Onefive Katana 通用型脉冲激光器
Onefive Origami 低噪声孤子飞秒光纤激光器
美国electrophysics公司 红外相机 7290A
Lyncee 数字全息显微镜 DHM R2100
electrophysics 红外热像仪 ATOM80
OKO N50mm 37/79/109通道压电变形镜(PDM)
Beam Analyzer光束质量分析仪
中红外光谱仪
光纤激光器
光纤放大器
