方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
研究领域:碳钢腐蚀 测量方法:塔菲尔曲线和交流阻抗 The electrochemical behavior of SAE-1020 carbon steel in 0.25 M Na2SO4 solution containing different concentrations of H2S at 90 C was investigated using the methods of weight loss, electrochemical measurements, scanning electron microscopy (SEM) and X-ray diffraction (XRD). The results showed that the corrosion rate of carbon steel increased significantly with the increase of H2S concentration.
