方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
研究领域:锂离子电池固体电解质 交流阻抗频率范围:200kHz - 10mHz The impact of ambient air exposure on LiFePO4/C nanocomposites has been investigated. A pristine sample was prepared without any exposure to ambient air through the whole process of synthesis and characterization and compared to the exposed samples. A small amount of lithium deintercalates from the olivine structure during exposure, a majority of which can be electrochemically reintercalated. This phenomenon changes the initial surface and bulk properties and should be taken into account when diminishing the particle size of LiFePO4. Keeping nanocomposites away from oxidative moisture atmosphere could be a solution to minimize these side reactions.
