为了答谢各位新老客户对我们一直以来的支持与帮助,同时也为了庆祝中国抗战胜利及迎接9.3天安门阅兵纪念活动的到来,我们现推出“金九、银十”大促销!
凡是购买以下现货产品的用户,同时其新订购的产品可享受5折优惠!现货产品一律48折清货,数量有限,欲购从速!
液相色谱柱:
9101562 1 Ultra C1 5um,150 x 2.1mm ¥2,482.00
9107562 1 Ultra 氨基柱 5um,150 x 2.1mm ¥2,482.00
9210512 1 Pinnacle II 硅胶柱 5um,100 x 2.1mm ¥1,945.00
9100565 1 Ultra 硅胶柱 5um 100A,150x4.6mm ¥2,482.00
9219572 1 Pinnacle II 多环芳烃柱 - 5um,250x2.1mm ¥2,649.00
9102565 1 Ultra C4 5um 100A,150x4.6mm ¥2,482.00
9107312 1 Ultra 氨基柱 3um 100A,100x2.1mm ¥2,482.00
9210562 1 Pinnacle II 硅胶柱 5um,150 x 2.1mm ¥2,055.00
9101312 1 Ultra C1 3um 100A,100x2.1mm ¥2,482.00
9100562 1 Ultra 硅胶柱 5um 100A,150x2.1mm ¥2,482.00
9177315 1 Ultra 氨基甲酸酯柱 3um,100 x 4.6mm ¥3,044.00
9410565 1 Pinnacle DB 硅胶柱 5um,150x4.6mm ¥2,343.00
9219565 1 Pinnacle II 多环芳烃柱 5um,150x4.6mm ¥2,545.00
9100312 1 Ultra 硅胶柱 3um 100A,100x2.1mm ¥2,482.00
9105565 1 Ultra 苯基柱 5um 100A,150x4.6mm ¥2,482.00
9105312 1 Ultra 苯基柱 3um 100A,100x2.1mm ¥2,482.00
9219575 1 Pinnacle II 多环芳烃柱 5um,250x4.6mm ¥2,649.00
9160312 1 Allure 硅胶柱 3um 60A,100x2.1mm ¥2,482.00
9215562 1 Pinnacle II 苯基柱 5um,150x2.1mm ¥2,055.00
9210312 1 Pinnacle II硅胶柱 3um,100 x 2.1mm ¥2,012.00
9177352 1 Ultra 氨基甲酸酯柱 3um,50 x 2.1mm ¥2,880.00
9101565 1 Ultra C1 5um 100A,150x4.6mm ¥2,482.00
9106312 1 Ultra 氰基柱 3um 100A,100x2.1mm ¥2,482.00
9176352 1 Ultra PFP(五氯苯酚)柱 3um 100A,50x2.1mm ¥2,371.00
9210565 1 Pinnacle II 硅胶柱 5um,150 x 4.6mm ¥2,055.00
9174562-700 2 Ultra C18 5um 100A,150x2.1mm, 带保护柱 ¥2,573.00
9174575 1 Ultra C18 5um 100A,250x4.6mm ¥2,852.00
9414575 10 Pinnacle DB C18 5um,250x4.6mm ¥2,506.00
9217575 1 Pinnacle II 氨基柱 5um,250x4.6mm ¥2,266.00
保护柱芯:
916450212 2 Allure C18,10 x 2.1mm 3-pk ¥946.00
921450212 5 Pinnacle II C18,10 x 2.1mm 3-pk ¥1,042.00
917550212 2 Ultra IBD,10 x 2.1mm 3-pk ¥946.00
917550210 2 Ultra IBD,10 x 4.0mm 3-pk ¥946.00
917450212 1 Ultra C18,10 x 2.1mm 3-pk ¥946.00
917850212 1 Ultra AQ C18,10 x 2.1mm 3-pk ¥946.00
910350212 1 Ultra C8,10 x 2.1mm 3-pk ¥946.00
气相色谱柱:
70123 1 MXT-1,30m, 0.25mm ID, 0.25um ¥3,000.00
13442 1 Rxi-5ms,60m, 0.32mm ID, 0.50um ¥5,280.00
10123 4 Rtx-1,30m, 0.25mm ID, 0.25um ¥2,660.00
12623 1 Rtx-5MS,30m, 0.25mm ID, 0.25um ¥2,952.00
其他耗材配件:
25022 1 柱筛,4mm 2um,Trident保护柱系统配件, 5pk ¥197.00
24619 17小盒 2ml螺纹口样品瓶,带白色刻度记号,100pk/小盒 ¥130.00
21142 33小盒 2.0 mL,9 mm短口,螺口瓶,100pk/小盒 ¥135.00
21140 22小盒 2.0 mL,9 mm短口,螺口瓶,100PK/小盒 ¥125.00
21194 8小盒 2.0 mL的自动进样器样品瓶方便套件,琥珀色,100pk/小盒 ¥250.00
21192 13小盒 2.0 mL的自动进样器样品瓶方便套件,透明,100pk/小盒 ¥236.00
24383 10小盒 2.0 mL钳口瓶,11 mm,带刻度记号 100pk/小盒 ¥125.00
21152 8小盒 2.0 mL钳口瓶,11 mm,不带刻度记号,100pk/小盒 ¥112.00
24655 7小盒 4.0 mL WISP 48 透明螺口瓶,100pk/小盒 ¥117.00
24656 5小盒 4.0 mL WISP 48 琥珀色螺口瓶,100pk/小盒 ¥260.00
21192 15小盒 2.0 mL的自动进样器样品瓶方便套,,透明,100pk/小盒 ¥236.00
24663 10小盒 1.0 mL WISP 96,8 x 40 mm 直型样品瓶 ¥478.00
24685 1小盒 顶空钳口样品瓶 20ml 23x75mm, 100PK ¥250.00
21799 1小盒 VOA检测专用样品瓶 20ml 琥珀色,72pk ¥610.00
21798 1小盒 VOA检测专用样品瓶 20ml 透明,72pk ¥543.00
22397 1瓶 IceBlue进样垫 17mm 现在替代27169
22384 1瓶 Thermolite进样垫 17mm
20383 1瓶 Thermolite进样垫 7mm 现在替代货号27128
22389 1瓶 IceBlu进样垫 9.5mm (3/8英寸)
22393 1瓶 IceBlue进样垫 11mm 现在替代27163
22391 1瓶 IceBlue进样垫 10mm 现在替代27161
20365 1瓶 Thermolite进样垫 11mm (3/8英寸) 现在替代27137
20361 1瓶 Thermolite进样垫 9.5mm (3/8英寸) 现在替代27137
24636 1小盒 2.0 mL,8 mm螺口瓶套装 琥珀色, 100 Pack ¥260.00
25084 1瓶 Trident直接式保护柱 ¥696.00
21776 1包 250ul 玻璃,大口插件,带底弹簧,100pk ¥538.00
24050 40支 SPE C18,3mL/500mg, 50pk,Resprep反相固相萃取柱 ¥893.00
24510 7小包 250ul 玻璃,平底插件, 100pk/小包 ¥678.00
25026 9包 XG-XF 接头,10mm ¥164.00
21770 1包 Snap Plug, Starburst,8mm, Clear Low Density Polyethylene 1000 pk ¥216.00
20205 1 石墨变径卡套,1/8" to 0.4/0.5mm 5pk ¥192.00
20201 1 石墨卡套,1/16" X 0.5mm ID 10pk ¥240.00
20142 1 1/16英寸 转接器聚酰亚胺卡套 5pk ¥267.00
25378 1 活塞杆密封垫,黑色(graphite-filled Teflon) ¥264.00
24520 4 250ul 聚丙烯,大口插件,无弹簧,100pk ¥78.00
24512 3 100ul 聚丙烯内插件,带底弹簧,100pk ¥149.00
24749 1 更换针(SGE)岛津 10ul,Model N10-S-0.63 10ul/23 Pack of 2 ¥198.00
24748 1 更换针(SGE)岛津 10ul,Model N10-S-0.47 10ul/26 Pack of 2 ¥198.00
25016 1 通用PEEK色谱柱堵头,10-32 10pk ¥255.00
25324 1 PEEK 色谱柱连接头(矩形截面),10-32 10pk ¥236.00
25015 1 PEEK色谱柱连接头(圆形),10-32 10pk ¥255.00
24516 1 广口样品瓶内衬管 250μL,玻璃,大口插件,带玻璃法兰,100pk ¥470.00
24511 1 100ul 聚丙烯内插件,无弹簧,100pk ¥115.00
24486 5包+4小包 2.0 mL,9 mm 短口,螺口盖,1000pk/包 ¥1,277.00
21175 2包+6小包 2mL,11mm铝制钳口盖,PTFE/天然橡胶密封,1000pk ¥586.00
24360 1包 (9个) 2ml,11mm铝制钳口盖,带隔垫,银色密封,PTFE/硅树脂,1000pk ¥1,335.00
24517 1包 (9个) 350ul 玻璃,平底插件, 1000Pk ¥783.00
21193 2包+1小包 2.0 mL的自动进样器透明样品瓶方便套件,1000pk ¥2,036.00
21147 1包 隔垫,8 mm x 0.065″,红色PTFE/白色硅树脂,1000pk ¥860.00
21743 4小包 4.0ml螺纹盖,带0.065"密封垫,预装,100pk ¥192.00
25594 7 气相色谱填料Porapak N 50/80 1瓶 - 29克 ¥1,320.00
22174 2 3.5mm 单锥精密衬管加灭活玻璃毛 5-pk,适用于岛津(Shimadzu)17A, 2010,2014 GCs ¥888.00
23137 1 Swagelok 黄铜配件,1/4" to 1/8" NPT 阳螺纹接头, 10-pk ¥384.00
24384 1 2.0ml透明,带白点记号,钳口瓶口,12x32mm/2.0mL/11mm 1000pk ¥903.00
22020 5 超净气体过滤器,三元载气过滤器,可去除氧/湿度/氢 ¥1,062.00
20423 1 Vu-Union 聚酰亚胺/石墨压环,1/16" X 0.3mm ID,10pk ¥380.00
22656 1 ProFLOW 6000手持式电子流量计 ¥4,365.00
25026 1 HPLC Trident 保护柱系统XG-XF 配件,10mm ¥164.00
25021 2 HPLC Trident 10mm保护柱座 ¥375.00
25040 1 HPLC Trident 10mm保护柱座,带过滤器 ¥504.00
25022 1 HPLC Trident保护柱系统 备用Cap Frits,4mm 2um, 5pk ¥197.00
普林斯顿分离纯化试剂盒
CS-400 2 分子排阻分离纯化试剂盒centri.spin 40 - 20 Pack
CS-100 1 分子排阻分离纯化试剂盒centri.spin 10 - 20 Pack
COM-124 1 COMBO-PAK 3 X 10 Columns
centri-sep protocol 23包 centri-sep protocol,3 pack/包,23pk
centri-spin 40 23包 分子排阻分离纯化试剂盒centri-spin 40,3 pack/包,23pk
CS-962 5 冲洗孔板 centri.sep96孔板
PP-121 6小瓶+4只管子 细菌人工染色体DNA纯化试剂盒套装,
适用于25-250ml的培养物的提取
数量有限,大家速速过来抢购吧!
NWE! Restek最新推出Roc LC柱—构造您实验室的基石
高比携手Restek,举行2016年终特惠
高比携手Restek,举行2016年终特惠!
高比科技——Restek液相柱子5折超值促销!!!
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
