特惠喜讯:
高比携手Restek,举行2016年终特惠,色谱柱商品1根特惠4折,3根特惠3.5折,数量有限售完为止.
9217575 Pinnacle II 氨基柱 5um,250x4.6mm
9414575 Pinnacle DB C18 5um,250x4.6mm
9174575 Ultra C18 5um 100A,250x4.6mm
9174562-700 Ultra C18 5um 100A,150x2.1mm, 带保护柱
9210565 Pinnacle II 硅胶柱 5um,150 x 4.6mm
9176352 Ultra PFP(五氯苯酚)柱 3um 100A,50x2.1mm
9106312 Ultra 氰基柱 3um 100A,100x2.1mm
9101565 Ultra C1 5um 100A,150x4.6mm
9177352 Ultra 氨基甲酸酯柱 3um,50 x 2.1mm
9210312 Pinnacle II硅胶柱 3um,100 x 2.1mm
9215562 Pinnacle II 苯基柱 5um,150x2.1mm
9160312 Allure 硅胶柱 3um 60A,100x2.1mm
9219575 Pinnacle II 多环芳烃柱 5um,250x4.6mm
9105312 Ultra 苯基柱 3um 100A,100x2.1mm
9105565 Ultra 苯基柱 5um 100A,150x4.6mm
9100312 Ultra 硅胶柱 3um 100A,100x2.1mm
9219565 Pinnacle II 多环芳烃柱 5um,150x4.6mm
9410565 Pinnacle DB 硅胶柱 5um,150x4.6mm
9177315 Ultra 氨基甲酸酯柱 3um,100 x 4.6mm
9100562 Ultra 硅胶柱 5um 100A,150x2.1mm
9101312 Ultra C1 3um 100A,100x2.1mm
9210562 Pinnacle II 硅胶柱 5um,150 x 2.1mm
9107312 Ultra 氨基柱 3um 100A,100x2.1mm
9102565 Ultra C4 5um 100A,150x4.6mm
9219572 Pinnacle II 多环芳烃柱 - 5um,250x2.1mm
9100565 Ultra 硅胶柱 5um 100A,150x4.6mm
9210512 Pinnacle II 硅胶柱 5um,100 x 2.1mm
9107562 Ultra 氨基柱 5um,150 x 2.1mm
9101562 Ultra C1 5um,150 x 2.1mm
货号 备注
910350212 Ultra C8,10 x 2.1mm 3-pk
917850212 Ultra AQ C18,10 x 2.1mm 3-pk
917450212 Ultra C18,10 x 2.1mm 3-pk
917550210 Ultra IBD,10 x 4.0mm 3-pk
917550212 Ultra IBD,10 x 2.1mm 3-pk
921450212 Pinnacle II C18,10 x 2.1mm 3-pk
25022 柱筛,4mm 2um,Trident保护柱系统配件, 5pk
916450212 Allure C18,10 x 2.1mm 3-pk
21744(21743) 4.0ml螺纹盖,带0.065"密封垫,预装,100pk
21147 隔垫,8 mm x 0.065″,红色PTFE/白色硅树脂,适合8mm螺纹瓶,1000pk
21193 2.0 mL的自动进样器透明样品瓶方便套件,螺纹盖,1000pk
24517 350ul 玻璃,平底插件, 1000Pk
24360 2ml,11mm铝制钳口盖,带隔垫,银色密封,PTFE/硅树脂,1000pk
21175 2mL,11mm铝制钳口盖,PTFE/天然橡胶密封,1000pk
24486 2.0 mL,9 mm 短口,螺口盖,1000pk
24511 100ul 聚丙烯内插件,无弹簧,100pk
24516 广口样品瓶内衬管 250μL,玻璃,大口插件,带玻璃法兰,100pk
25015 PEEK色谱柱连接头(圆形),10-32 10pk
25324 PEEK 色谱柱连接头(矩形截面),10-32 10pk
25016 通用PEEK色谱柱堵头,10-32 10pk
24748 更换针(SGE)岛津 10ul,Model N10-S-0.47 10ul/26 Pack of 2
24749 更换针(SGE)岛津 10ul,Model N10-S-0.63 10ul/23 Pack of 2
24512 100ul 聚丙烯内插件,带底弹簧,100pk
24520 250ul 聚丙烯,大口插件,无弹簧,100pk
25378 活塞杆密封垫,黑色(graphite-filled Teflon)
20142 1/16英寸 转接器聚酰亚胺卡套 5pk
20201 石墨卡套,1/16" X 0.5mm ID 10pk
20205 石墨变径卡套,1/8" to 0.4/0.5mm 5pk
21770 Snap Plug, Starburst,8mm, Clear Low Density Polyethylene Pack of 1000
25026 XG-XF 接头,10mm
24510 250ul 玻璃,平底插件, 1000pk
24050 SPE C18,3mL/500mg, 50pk,Resprep反相固相萃取柱
21776 250ul 玻璃,大口插件,带底弹簧,100pk
25084 Trident直接式保护柱
24636 2.0 mL,8 mm螺口瓶套装 琥珀色, 100 Pack
20361 Thermolite进样垫 9.5mm (3/8英寸) 现在替代27137
20365 Thermolite进样垫 11mm (3/8英寸) 现在替代27137
22391 IceBlue进样垫 10mm 现在替代27161
22393 IceBlue进样垫 11mm 现在替代27163
22389 IceBlu进样垫 9.5mm (3/8英寸)
20383 Thermolite进样垫 7mm 现在替代货号27128
22384 Thermolite进样垫 17mm
22397 IceBlue进样垫 17mm 现在替代27169
21798 VOA检测专用样品瓶 20ml 透明,72pk
21799 VOA检测专用样品瓶 20ml 琥珀色,72pk
24685 顶空钳口样品瓶 20ml 23x75mm, 100PK
24663 1.0 mL WISP 96,8 x 40 mm 直型样品瓶
21193(21192) 2.0 mL的自动进样器样品瓶方便套,带螺纹盖,透明,100pk
24657(24656) 4.0 mL WISP 48 琥珀色螺口瓶,1000pk
24655 4.0 mL WISP 48 透明螺口瓶,1000pk
21153(21152) 2.0 mL钳口瓶,11 mm,不带刻度记号,100pk/小盒
24384(24383) 2.0 mL钳口瓶,11 mm,带刻度记号 100pk/小盒
21193(21192) 2.0 mL的自动进样器样品瓶方便套件,带螺纹盖,透明,100pk/小盒
21195(21194) 2.0 mL的自动进样器样品瓶方便套件,带螺纹盖,琥珀色,100pk/小盒
21141(21140) 2.0 mL,9 mm短口,螺口瓶,100PK/小盒
21143(21142) 2.0 mL,9 mm短口,螺口瓶,100pk/小盒
24620(24619) 2ml螺纹口样品瓶,带白色刻度记号,100pk/小盒
NWE! Restek最新推出Roc LC柱—构造您实验室的基石
“金九、银十”大促销!
高比科技——Restek液相柱子5折超值促销!!!
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
