方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Introduction Hybrid silphenylene backbone modied siloxane capillary GC stationary phases were commercially introduced two decades ago. These hybrid siloxanes demonstrated increased thermal stability over the conventional low polarity phases they were designed to mimic. The changes in physical properties induced by the insertion of rigid benzene ring bridges into the exible siloxane backbone also requires modications in surface chemistries to achieve good wettability and lm stability in order to maintain column eciency. Several years later, a second generation of more polar hybrid stationary phases was introduced. These polymers, designed to mimic 35% and 50% phenyl containing siloxanes, also often incorporated other types of aromatic backbone modications to further enhance thermal stability. Even more exotic surface chemistries were required to achieve wettablity while maintaining good deactivation. There are always trade-os and, in the end, deactivation often suered in the interest of column eciency. Recent application of new cross-bonding and deactivation chemistries to a 35% phenyl equivalent hybrid siloxane stationary phase has resulted in advances in both column eciency and inertness. These new columns display improved inertness for the analysis of highly polar compounds, producing symmetrical peaks for both basic and acidic compounds while maintaining high column eciencies.
8分钟轻松完成EPA常规邻苯二甲酸酯检测
麻醉品中毒品成分的定性分析应用文献
毛细管气相色谱法测定盐酸金刚乙胺片的溶出度的应用文献
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
