方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
高比科技 侯先生 13691497252 “Weathering” of Aroclor mixes that have been in the environment for more than 30 years and changes in Aroclor patterns in tissue samples, due to bioaccumulation have made identification and quantification of Aroclor mixes difficult. Consequently, many laboratories are analyzing long lists of PCB congeners, using the data to determine specific congener patterns, and compiling congener results to obtain an accurate total PCB concentration. Identification and quantification of PCB congeners is chromatographically challenging because there are 209 possible combinations in which chlorine atoms can be added to the biphenyl structure, ranging from addition of single chlorine (monochlorobiphenyls) to addition at every available carbon atom (decachlorobiphenyl). In 1996, George Frame published work he performed in order to determine which PCB congeners are present in Aroclor mixes. Using this work as a guide, the list of 209 possible PCB congeners can be reduced to a target list of 158 congeners. Several congeners not found in Aroclors but found in animal tissues, such as PCB#169, have been added. The list encompasses the seven European indicator compounds and the 12 most toxic congeners listed by the World Health Organization (WHO) list.
8分钟轻松完成EPA常规邻苯二甲酸酯检测
麻醉品中毒品成分的定性分析应用文献
毛细管气相色谱法测定盐酸金刚乙胺片的溶出度的应用文献
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
