方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
请点击链接 http://www.restek.com/aoi_env_A012.asp 高比科技 13691497252 Analysis of Brominated Flame Retardants on an Rxi™-5ms Optimizing Method Conditions to Reliably Quantify BFRs By Jason Thomas, Environmental Chemist Minimal breakdown, symmetric peaks for heat-sensitive PBDEs. Complex samples well resolved, for reliable identifications. Low bleed baselines help ensure accurate quantification. Brominated flame retardants (BFRs) are widely used but potentially harmful materials currently being monitored in the environment. Analysis of higher molecular weight polybrominated diphenyl ethers (PBDEs) can present a particular problem: relatively high temperatures are required to elute them from a GC column, but they are easily debrominated at elevated temperatures. Poor peak shapes and extraneous peaks from breakdown products can complicate the analysis. Therefore, several key parameters must be optimized to ensure proper analysis of these compounds.
8分钟轻松完成EPA常规邻苯二甲酸酯检测
麻醉品中毒品成分的定性分析应用文献
毛细管气相色谱法测定盐酸金刚乙胺片的溶出度的应用文献
75 Comp TO15 + NJ Mix (75 components)
10 Comp NJ Subset Test Mix (10 组分)
74 Comp TO15 + NJ Mix, (没有丙烯醛) (74 组分)
606 邻苯二甲酸酯类校准混合物 (6种成分)
方法 506(邻苯二甲酸酯&己二酸酯) 校准混合物 (7种成分)
8040 酚类化合物混合物 #2 (9 种成分)
8040 酚类化合物混合物 #1 (9 种成分)
8040 替代品混合物 (2种成分)
604 酚类化合物校准混合物 (11 种成分)
酚类加标混合物, EPA 528 (12 种成分)
苯酚校准混合物, EPA 528 (12 种成分)
拟似标准品混合物, EPA 528 (3 种成分)
方法 528 (酚类化合物)
明尼苏达州农业部列表1 杀虫剂 套件
明尼苏达州农业部列表1 杀虫剂混合物 B (6种成分)
