方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abrasion Testing Equipment for Mechanical Seal ◆Summary and Testing Purpose The purpose of this testing equipment is to evaluate the abrasive characteristics of mechanical seal components. This testing equipment roughly simulates the real situation of mechanical seal and tests the sliding/frictional characteristics of mechanical seal. The Equipment is composed of testing unit, actuator, and load mechanism for axial force. Also, water-feeding unit conveys water to testing unit and testing controller carries out testing and control.
浅谈标准定量测氢装置(HTDS)在材料行业的应用以及创制耐氢脆耐腐蚀材料新方针
