sRANKL Mouse 重组小鼠可溶性RANK配体/sRANKL Mouse
Synonyms | Soluble Receptor Activator of NFkB Ligand, TNFSF11, TRANCE, TNF-related activation-induced cytokine, OPGL, ODF, Osteoclast differentiation factor, Tumor necrosis factor ligand superfamily member 11, Receptor activator of nuclear factor kappa B ligand, RANKL, Osteoprotegerin ligand, CD254 antigen, sRANKL, sOdf. |
Introduction | RANKL binds to tnfrsf11b/opg and to tnfrsf11a/rank. Osteoclast differentiation and activation factor. augments the ability of dendritic cells to stimulate naive t-cell proliferation. May be an important regulator of interactions between t-cells and dendritic cells and may play a role in the regulation of the t-cell-dependent immune response. sRANKL may also play an important role in enhanced bone-resorption in humoral hypercalcemia of malignancy. |
Description | sRANKL Mouse Recombinant produced in E.coli is single, non-glycosylated, polypeptide chain containing 174 amino acids and having a total molecular mass of 19.9kDa. CD254 is purified by proprietary chromatographic techniques. |
Source | Escherichia Coli. |
Physical Appearance | Sterile Filtered White lyophilized (freeze-dried) powder. |
Formulation | The protein (1mg/ml) was lyophilized with 10mM Na2PO4, pH 7.5 & 50mM NaCl. |
Solubility | It is recommended to reconstitute the lyophilized sRANKL in sterile 18MΩ-cm H2O not less than 100μg/ml, which can then be further diluted to other aqueous solutions. |
Stability | Lyophilized TNFSF11 although stable at room temperature for 3 weeks, should be stored desiccated below -18°C. Upon reconstitution sRANKL should be stored at 4°C between 2-7 days and for future use below -18°C. For long term storage it is recommended to add a carrier protein (0.1% HSA or BSA). Please prevent freeze-thaw cycles. |
Amino acid sequence | PAMMEGSWLD VAQRGKPEAQ PFAHLTINAA SIPSGSHKVT LSSWYHDRGW AKISNMTLSN GKLRVNQDGF YYLYANICFR HHETSGSVPT DYLQLMVYVV KTSIKIPSSH NLMKGGSTKN WSGNSEFHFY SINVGGFFKL RAGEEISIQV SNPSLLDPDQ DATYFGAFKV QDID. |
Purity | Greater than 95.0% as determined by SDS-PAGE. |
Biological Activity | Measured by its ability to induce osteoclast formation on murine RAW264.7 cells using a concentration of 50ng/ml shown in “Corning® Osteo Assay Surface 24 Well Plates with Transwell® Permeable Supports- A Useful Tool for Co-Culture Studies” by Rebecca M. Wood and Mark Rothenber, corresponding to a specific activity of 20,000Units/mg. |
Usage | ProSpec's products are furnished for LABORATORY RESEARCH USE ONLY. The product may not be used as drugs, agricultural or pesticidal products, food additives or household chemicals. |
Prodigiosin/灵菌红素的PubChem识别号5351169
优质前列腺素E2Mouse PGE2,PG-E2 ELISA试剂盒有国外文献支持
进口操作说明重组二甲基甘氨酸氧化酶/DMGO
以色列进口小鼠白介素-6/IL 6 Mouse
人胃泌素(Gastrin)ELISA试剂盒Human Gastrin ELISA Kit
人胃动素(MTL)ELISA试剂盒Human MTL ELISA Kit
人胃蛋白酶(PG)ELISA试剂盒Human Pepsin ELISA Kit
人维生素D3(VD3)ELISA试剂盒Human VD3 ELISA kit
人维生素B1(VB1)ELISA试剂盒Human Vitamin B1 ELISA kit
人晚期氧化蛋白产物(AOPP)ELISA试剂盒Human AOPP ELISA Kit
人晚期糖基化终末产物受体(RAGE/AGER)ELISA试剂盒Human RAGE/AGER ELISA Kit
人晚期糖基化终末产物(AGEs)ELISA试剂盒Human AGEs ELISA Kit
人唾液酸(SA)ELISA试剂盒Human,SA ELISA Kit
人褪黑素(MT)ELISA试剂盒Human,MT ELISA Kit
人透明质酸(HA)ELISA试剂盒Human,HA ELISA Kit
人同型半胱氨酸(Hcy)ELISA试剂盒Human,Hcy ELISA试剂盒
人铁蛋白(FE)ELISA试剂盒Human,FE ELISA试剂盒
人天门冬氨酸氨基转移酶(AST)ELISA试剂盒Human AST ELISA试剂盒
人糖原磷酸化酶同工酶BB(GP-BB)ELISA试剂盒Human GP-BB ELISA试剂盒
