方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Intermembrane lipid exchange is critical to membrane functions and pharmaceutical applications. The exchange process is not fully understood and it is explored by quartz crystal microbalance with dissipation monitor method in this research. It is found that intermembrane lipid exchange is accelerated with the decrease of vesicle size and the increase of charge and liquid crystalline lipid composition ratio. Vesicle adsorption rate, membrane lateral pressure gradient, and lipid lateral diffusion coefficient are inferred to be critical in deciding the lipid exchange kinetics between membranes. Besides that, the membrane contact situation during lipid exchange is also studied. The maximum total membrane contact area is found to increase with the decrease of vesicle size, charged and liquid crystalline lipid composition ratio. A competition mechanism between the vesicle adsorption rate and the intermembrane lipid exchange rate was proposed to control the maximum total membrane contact area.
QSense耗散型石英晶体微天平在制药领域中的应用
使用QCM-D 进行清洁研究
海南大学化工学院李嘉诚教授利用石英晶体微天平技术研究光响应性海藻酸基大分子表面活性剂与疏水叶片表面的相互作用
Attension Theta Flow 光学接触角测量仪
QSense High Pressure 高压石英晶体微天平
QSense全自动八通道石英晶体微天平
QSense卓越版四通道石英晶体微天平
QSense Explorer扩展版石英晶体微天平
KSV NIMA roll to roll 柔性LB膜制备系统
KSV NIMA LB膜分析仪
Attension Theta Flex 光学接触角仪
KSV NIMA Microbam 独立式小型布鲁斯特角显微镜
KSV NIMA 布鲁斯特显微镜
KSV NIMA常规 交替型LB膜分析仪
KSV NIMA 缎带型Langmuir膜分析仪
KSV NIMA Langmuir膜分析仪
QSense 石英晶体微天平定制表面芯片
高温高压表面/界面测量系统
