方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
空心胶囊中重金属铬的检测一般采用石墨炉原子吸收光谱法,参照标准:GB/T5009.123-2003食品中铬的测定。北京化标源科技有限公司对空心胶囊中铬含量检测所用试剂的推荐:
关于瘦肉精的检测
HYDRANAL®-Xylene Solvent
HYDRANAL®-Salicylic acid Buffer substance
HYDRANAL®-Imidazole Buffer substance
HYDRANAL®-Chloroform Solvent
HYDRANAL®-Buffer Base Buffer substance
HYDRANAL®-Moisture Test Kit Test kit
HYDRANAL®-LipoSolver MH reagent
HYDRANAL®-LipoSolver CM reagent
HYDRANAL®-Methanol Rapid reagent
Karl Fischer reagent solution B
Karl Fischer reagent solution A
Karl-Fischer reagent
HYDRANAL®-Coulomat Oil reagent
HYDRANAL®-Water Standard 10.0 standard
HYDRANAL®-Water Standard 0.1 standard
