Characterization of molybdenum
2011/07/27   下载量: 3
方案下载
应用领域
检测样本
检测项目
参考标准
Molybdenum nitride coatings were deposited onto high-speed steel (HSS) substrates by the arcPVD technique. It was possible to producecoatings with MO%N and MoN structure by varying the nitrogen partial pressure between 0.4 and 1.5 Pa. The relationships between hardness, thickness, and crystallographic structure of the coating and the deposition parameten were investigated. Hardness of the coatings increased with the increase of nitrogen content of the coating. Tribological behavior of the coatings was detennined by ball-on-disk wear tests. The wear behavi~ of Mo-N~oated HSS samples against alumina balls was better than that of TIN-coated ~Electrochemical polarization experiments were conducted in 1 N sulfuric acid. The porosity of the samples was detemtined by the copper decoration test The coating with the lowest nitrogen content showed the best com)Sjon protective properties in the electrochemical tests. C 1997 Elsevier Science SA.
方案下载
配置单
上一篇 案例分析-凸轮轴
下一篇 paper 637 试验机用真实润滑油衡量活塞环、缸套摩擦磨损
文献贡献者
相关方案
当前位置: 奥码拓 方案 Characterization of molybdenum
