paper 637 试验机用真实润滑油衡量活塞环、缸套摩擦磨损
2012/03/13   下载量: 3
方案下载
应用领域
检测样本
检测项目
参考标准
Abstract Laboratory tests to evaluate piston ring and cylinder liner materials for their friction and wear behavior in realistic engine oils are describe to support the development of new standard test methods. A ring segment was tested against a flat specimen of gray cast iron typical o cylinder liners. A wide range of lubricants including Jet A aviation fuel, mineral oil, and a new and engine-aged, fully formulated 15W4 heavy duty oil were used to evaluate the sensitivity of the tests to lubricant condition. Test temperatures ranged from 25 to 100 8C. A steppe load procedure was used to evaluate friction behavior using a run-in ring segment. At 100 8C, all lubricants showed boundary lubricatio behavior, however, differences among the lubricants could be detected. Wear tests were carried out at 240 N for 6 h at 100 8C with new rin segments. The extent of wear was measured by weight loss, wear volume and wear depth using a geometric model that takes into accoun compound curvatures before and after testing. Wear volume by weight loss compared well with profilometry. Laboratory test results ar compared to engine wear rates.
方案下载
上一篇 案例分析-凸轮轴
下一篇 paper 635 微动检测涂层强度
文献贡献者
相关方案
当前位置: 奥码拓 方案 paper 637 试验机用真实润滑油衡量活塞环、缸套摩擦磨损
