资料下载Ondax’s 785nm, 600mW Wavelength Stabilized Laser is a multi-mode, miniature laser in a butterfly, fiber-coupled package with integrated TEC. The stabilization is achieved using the Ondax Volume Holographic Grating (VHG) PowerLocker . The laser has a very low temperature dependence and precise center wavelength over the locked region.
单频光纤耦合激光器
简介:The Ondax FCLM Series of laser modules provide a very narrow linewidth and long coherence length with a precise center wavelength. The frequency stabilized, fiber coupled, laser module is stabilized using the Ondax volume Holographic Grating (VHG) PowerLocker . The unit is remotely controllable via an analog control interface.
405nm 波长稳定的激光器模块
简介:Ondax’s SureLock 405nm Laser Diode Module incorporates the Ondax PowerLocker VHG to deliver steady, wavelengthstabilized single frequency performance in an ultracompact footprint. Offering both computer and integrated user controls, the LM Series i n c l u d e s p r e c i s i o n temperature and current controls to deliver better than 1m coherence length and 1% power stability with less than 1 minute warm-up.
单频准直激光器模块
简介:The Ondax series of Single Frequency Collimated Laser Modules feature wavelengths from 405nm to 808nm with an integrated TEC and driver circuit in a compact, selfcontained,and rugged package. The built-in temperature controller maintains the laser diode temperature within ±0.01ºC resulting in excellent power stability that varies less than 1% over long term.
785nm高功率准直窄线宽单频激光器
简介:Ondax’s 785nm, 500mW Wavelength Stabilized Laser is a multi-mode, miniature laser in a collimated 9mm TO package. The stabilization is achieved using the Ondax Volume Holographic Grating (VHG) PowerLocker . The laser has a very low temperature dependence and precise center wavelength
Semilab GES5E全光谱椭偏仪
Semilab WT-1200A 少子寿命测试仪
SEMILAB DS95扫描探针显微镜
Semilab SOPRA SE-2000 GES5-E光谱椭偏仪
立陶宛EKSMA Optics公司激光光学元件
DLS-83D型深能级瞬态谱仪DLTS
WT-2000型少子寿命测试仪
EKSMA KTP普克尔盒
EKSMA BBO普克尔盒
EKSMA KDP普克尔盒
EKSMA DPS/DPD 普克尔盒驱动
EKSMA DP-SP短脉冲普克尔盒驱动
EKSMA标准铝外壳封装的单极普克尔盒驱动
EKSMA标准铝外壳封装的双极普克尔盒驱动
EKSMA FULL-BRIDGE普克尔盒驱动
