来自澳大利亚塔斯马尼亚大学的Andrew McMinn教授采用CTG FastOcean FRRf用于南极洲冰下的初级生产力研究。
Marine photosynthesis is responsible for approximately half the oxygen in our atmosphere. In other words the oxygen in every second breath we take comes from the ocean. For the last 10 years Professor Andrew McMinn and his team from the Institute for Marine and Antarctic Studies, University of Tasmania have been using a Chelsea FastOcean Fast Repetition Rate fluorometer (FRRf) to gain an insight into primary production, photosynthesis and photosynthetic health in the Southern Ocean and Antarctic.
His most recent deployments unearthed some new and interesting results relating to the physiological adaptations of Antarctic phytoplankton surviving in almost complete darkness under the East Antarctic sea ice.
The growth and retreat of Antarctic sea ice is the greatest seasonal cycle on Earth, and one that has a profound influence on the organisms that live in the region. Professor McMinn’s interest is in the very base of the food chain, the phytoplankton and single celled algae that are the foundation for the whole Antarctic ecosystem. Phytoplankton photosynthesize and produce oxygen just like the trees and land plants you see around you everyday. Marine photosynthesis is responsible for approximately half the oxygen in our atmosphere. Changes in sea ice extent and thickness will have massive affects on the phytoplankton and algae in the Southern Ocean and Antarctic regions. Professor McMinn’s interest is in investigating how these changes will play out and how they will influence these extremely important photosynthetic organisms we rely so much on.
Professor McMinn and his team own a number of Chelsea FRR fluorometers. These are deployed from ships (usually large icebreakers) in vertical profiling mode, usually along side CTDs, and in an underway flow through set ups. On their most recent mission the FastOcean ADP Profiling System was deployed through a hole in the sea ice and lowered by hand using a tripod and winches (see photo above).
"The main challenge we face during our regular deployments in the Antarctic," said Professor McMinn "is working in temperatures below -30°C. These conditions are particularly tough on electronic equipment but we were pleasantly surprised with the performance of the FastOcean on our recent Antarctic expedition. The only difficulty, aside from reduced battery life that occurs with all devices in the cold, we experienced with the FastOcean was freezing of the externally mounted dark chamber and pump. This was overcome by pre-heating super saline water and filling the chamber, hosing and pump with this liquid prior to deployment. Once the instrument was in the water the pump behaved normally."
【应用】基于无人机系统(UAS)的甲烷排放测量
【时讯】奕枫仪器携手德国TriOS共同参加2024上海环博会
【时讯】奕枫仪器受邀参加“第22届中国水色遥感大会”
【时讯】西班牙D.nota/Bettair公司到访奕枫仪器
定量过滤技术积分腔吸收计
点光源积分腔吸收计
TriOS EGC洗涤水排放监测系统更换/组装配件
MIRA Ultra便携式温室气体分析仪(CH4 /N2O/CO2/H2O)
UviLux FUEL - BTEX苯系物荧光计
TE-Wilbur 便携式PM10&PM2.5采样器
RAMSES G2自容式高光谱辐射计
OPUS UV深海硝酸盐测量仪
TriOS船舶废气清洁系统(EGC)水质监测仪
近海温盐深(CTD)及多参数监测系统
pHiDO 溶解氧&pH传感器
OPUS aero高浓度硝酸盐&亚硝酸盐测量仪
NICO plus增强型硝酸盐测量仪
microFlu V2荧光计
ProCeas激光红外气体分析仪
