方案下载应用领域 | 制药 |
检测样本 | 其他 |
检测项目 | 特殊物质和基团 |
参考标准 | GB/T 8**** |
Homopolymers and block copolymers of higher epoxides (butene oxide and hexene oxide) are synthesized using 1-alkanols and PEG-MME 1100 as initiators by anionic ring opening polymerization in bulk employing controlled microwave heating in sealed vessels. The selectivity of polymerization of higher epoxides and the effect of different reaction parameters on the formation of side products is discussed. A procedure for the generation of fairly clean homopolymers and multiblock copolymers (giving bottle–brush and cone type of structures) is developed.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
