方案下载应用领域 | 化药/中药/生物制药 |
检测样本 | 其他 |
检测项目 | 特殊物质和基团 |
参考标准 | GB/T 8**** |
End functionalized poly(propylene oxide)s with n-alkyl endgroups are synthesized by anionic ring opening polymerization of propylene oxide (PO) in bulk employing controlled microwave heating in sealed vessels. Different alcohols ranging from n-butanol to n-octadecanol are used as initiator and 2–10 propylene oxide units are added on average. A continuous decrease of internal pressure during the sealed vessel experiment reflects the consumption of PO monomer and the completion of the reaction is confirmed by a drop of the internal pressure to zero. The products are characterized by size exclusion chromatography (SEC), liquid chromatography at critical conditions (LCCC) and liquid adsorption chromatography (LAC). SEC with coupled density and refractive index (RI) detection provides information on the chemical composition along the molar mass distribution. LCCC allows a separation of the individual polymer homologous series according to their end groups. In LAC, the alkyl terminated chains elute later than the non-functional chains and can be separated to the baseline according to the number of repeat units.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
