方案下载应用领域 | 制药 |
检测样本 | 其他 |
检测项目 | 特殊物质和基团 |
参考标准 | GB/T 8**** |
Some 5,6-dihydropyrazolo/pyrazolo[1,5-c]quinazoline derivatives were rationally designed, synthesized and evaluated for in vitro xanthine oxidase inhibitory activity for the first time. Some notions about structure activity relationships are presented. The compounds 6g, 6h and 6e were found to be significantly active against XO. The compound 6g emerged as the most potent XO inhibitor as compared to allopurinol and free radical scavenger. The molecular docking of 6g into the XO active site highlighted its mode of binding and important interactions such as hydrogen bonding, p–p stacking with amino acid residues like Ser876, Thr1010, Phen914, Phe1009 and Phe649 and its close proximity to dioxothiomolybdenum (MOS).
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
