方案下载应用领域 | 制药 |
检测样本 | 化药新药研发 |
检测项目 | 其他>方法开发 |
参考标准 | GB/T 8**** |
The ethanolic extract of Aloe barbadensis Miller leaf skin showed inhibitory activity against phosphodiesterase-4D (PDE4D), which is a therapeutic target of inflammatory disease. Subsequent bioassay-guided fractionation led to the isolation of two new anthrones, 6′-Oacetyl- aloin B (9) and 6′-O-acetyl-aloin A (11), one new chromone, aloeresin K (8), together with thirteen known compounds. Their chemical structureswere elucidated by spectroscopic methods including UV, IR, 1D and 2DNMR, and HRMS. All of the isolateswere screened for their inhibitory activity against PDE4D using tritium-labeled adenosine 3′,5′-cyclic monophosphate (3H cAMP) as substrate. Compounds 13 and 14were identified as PDE4D inhibitors,with their IC50 values of 9.25 and 4.42μM, respectively. These achievements can provide evidences for the use of A. barbadensis leaf skin as functional feed additives for anti-inflammatory purpose.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
