方案下载应用领域 | 制药 |
检测样本 | 化药新药研发 |
检测项目 | 其他>方法开发 |
参考标准 | GB/T 8**** |
Reported herein is the total synthesis of zincophorin methyl ester, a polyketide ionophore. Of particular interest is the use of sterically hindered nucleophiles to surmount the unfavorable stereochemical outcome, leading to acetate aldol adducts, in nucleophilic addition to the aldehyde derived from propionates. The approach is based on the addition of an enoxysilane (bearing a removable phenylselenide moiety) to generate selectively FelkineAnh adducts in a BF3,OEt2-mediated Mukaiyama aldol reaction. Subsequent reduction of the selenide group led to the corresponding syn-aldol acetate motif, and this approach was applied to induce selectively the C12eC13 relationship of zincophorin.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
