方案下载应用领域 | 制药/生物制药 |
检测样本 | 化药新药研发 |
检测项目 | 其他>方法开发 |
参考标准 | GB/T 8**** |
We report herein a method that allows for the formation of a CeN bond between the Ce3 carbon of alactams and the nitrogen atom of indoles. A general procedure for the coupling of indoles and a-lactams in only 25 min with high yield is reported. The scope of the reactionwas extended by the development of a method for the in situ generation of less stable phenyl-substituted a-lactams. The developed method provides an atom-economical method for the formation of substituted a-amino amides that are found in a variety of biologically-active compounds.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
