方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Betulinic acid and its derivatives are potential bioactive compounds present in nature. This study investigated the biotransformation of betulin to betulinic acid by Cunninghamella blakesleeana cells. LC–MS analysis demonstrated that betulin could be transformed into at least five products from cultured C. blakesleeana cells, among which betulinic acid was the most important. The presented method provides an attractive alternative approach to chemical synthesis, because is less time-consuming and more environmentally friendly. C. blakesleeana can transform betulin into potent derivatives with high pharmacological activities.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
