方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
The 3-aryl-2-cyanoacrylamide scaffold was designed as core pharmacophore for inhibitors of the Dengue and West Nile virus serine proteases (NS2B-NS3). A total of 86 analogs was prepared to study the structure–activity relationships in detail. Thereby, it turned out that the electron density of the aryl moiety and the central double bond have a crucial influence on the activity of the compounds, whereas the influence of substituents of the amide residue is less relevant. The para-hydroxy substituted analog was found to be the most potent inhibitor in this series with a Ki-value of 35.7 lM at the Dengue and 44.6 lM at the West Nile virus protease. The aprotinin competition assay demonstrates a direct interaction of the inhibitor molecule with active centre of the Dengue virus protease. The target selectivity was studied in a counterscreen with thrombin and found to be 2.8:1 in favor of DEN protease and 2.3:1 in favor of WNV protease, respectively.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
