方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Fragment-based drug discovery is a valuable tool in hit identification, as well as the combination of different small fragments showing a minimal binding activity against biological receptors or enzymes to give merged hits. A high number of fragments on the same scaffold improve the probability to find a candidate showing single- or multi-target affinities. A rapid and versatile approach for synthesizing libraries of densely fragment-functionalized scaffolds is reported. Many fragments were assembled in few steps around a triazole ring starting from amino alcohols and other readily available building blocks. A binding assay against integrin avb3 was used as a test-bed in order to demonstrate the potential of such an approach in hit discovery strategies.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
