方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Dereplication methodology using UHPLC–DAD–QTOFMS was applied during the metabolic profiling investigation of the endophyte Setophoma sp., a fungus isolated from symptomless guava fruits. The approach performed allowed a fast analysis of the microbial secondary metabolites. From this fungus, seven highly C-alkylated depsides were isolated and identified as polyketides thielavins S, T, U and V and lecanorins D, E and F. Their structures were elucidated through spectroscopic methods including NMR, HRMS and especially with assistance of HRMS/MS experiments. The compounds were tested for quorum sensing regulation activity in the virulence gene expression of Staphylococcus aureus, but no inhibitory effect was detected. Nevertheless, moderate antibacterial activity was encountered in three of tested depsides, particularly with thielavin T, whose MIC was 6.25 lg/mL against S. aureus.
优选 KNAUER(德国诺尔)IJM 冲击射流混合系统Customized NanoProducers
型号:Customized NanoProducers优选 KNAUER(德国诺尔)IJM 冲击射流混合系统SingleCore NanoProducer
型号: IJM SingleCore NanoProducer优选 KNAUER(德国诺尔)IJM 冲击射流混合系统 IJM NanoScaler
型号:IJM NanoScaler优选 KNAUER(德国诺尔)IJM 冲击射流混合系统IJM DuoCore NanoProducer
型号:IJM DuoCore NanoProducer耐士科技:使用Biotage Isolera快速纯化液相制备色谱从库拉索芦荟叶皮提取天然的磷酸二酯酶抑制剂by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成大麻素及其代谢产物的定量半定量测定by耐士科技
耐士科技:通过Biotage Isolera快速纯化液相制备色谱帮助进行人体尿液中合成烷基羟基代谢物的定量半定量测定by耐士科技
KNAUER(德国诺尔) 高压制备液相色谱
KNAUER(德国诺尔)中压制备色谱
KNAUER(德国诺尔)Bio蛋白质层析纯化系统
KNAUER(德国诺尔) SMB模拟移动床色谱
KNAUER(德国诺尔)K-7400S冰点渗透压仪
NMN|β-烟酰胺单核苷酸 |CAS:1094-61-7
KNAUER(德国诺尔)制备柱
