方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
• ELSEVIER ScienceDirect www.elsevier.com/locate/yabio Analytical Biochemistry 368 (2007) 33–38 An assay for thiaminase I in complex biological samples 重组生物样品中硫胺酶I的活性检测-美国康奈尔大学 本实验所涉及的样品(鱼)经干燥后,在SPEX 6850冷冻研磨机内进行研磨,所得粉末即用于酶的提取. Jeremiah W. Hanes a, Clifford E. Kraft b, Tadhg P. Begley a,* a Department of Chemistry and Chemical Biology, Cornell University, Ithaca, NY 14853, USA b Department of Natural Resources, Cornell University, Ithaca, NY 14853, USA R eceived 8 November 2006 Available online 7 June 2007 Abstract An alternative method for measuring thiaminase I activity in complex samples is described. This assay is based on the selective consumption of the highly chromophoric 4-nitrothiophenolate by thiaminase I, resulting in a large decrease in absorbance at 411 nm. This new assay is simple and sensitive, and it requires only readily available chemicals and a visible region spectrophotometer. In addition, the assay is optimized for high-throughput analysis in a 96-well format with complex biological samples. Published by Elsevier Inc.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
