方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
X-ray Fluorescence Analysis of Cements 采用加拿大Katanax熔融机 The combination of a borate fusion and "Delta-Coefficient'' corrections for matrix effects is shown to yield a method for the analysis of cements in which high accuracy, rapidity, and slmpllcity are compatible. The features of the method are: (a) Counting statistics is nearly the only source of errors. (b) Weighing of flux and sample are nearly the only manipulations. (c) One standard only is required. (d) When cement composition is rather constant, the method described can be shortened significantly. The analysis of the six major elements In NBS-633-639 cements was performed with an average accuracy of 0.07 YO.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
