方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Vertrel XF, a DuPont product, is finding increased acceptance as a grinding aid. A fluorocarbon fluid, it prevents sample caking during grinding, and quickly evaporates from an open grinding container without leaving any residue. (Users should of course consult the DuPont Material Safety Data Sheet to determine incompatibility with other materials.) Our experience is that the “grindability” of almost any sample is enhanced by the use of Vertrel XF, contamination is lowered, and the grinding container is easier to clean. Typical XRF samples such as cement, rock, clinker, and similar material can be routinely ground below 10 microns. The technique that follows was pioneered by John Anzelmo and colleagues at Bruker AXS,* and is here adapted for SPEX CertiPrep, Inc. equipment: in an 8501 Hardened Steel Grinding Container load together 10 grams of sample, 2.5 grams of 3644 Ultrabind binder, and 7 ml of Vertrel XF. Grind in an 8515 Shatterbox for 2.0 minutes, then open the grinding container in a hood until the Vertrel XF has evaporated. Prepare a 3614 40mm Pellet Die with a flared 3617 Spec-Cap, and transfer the ground sample/binder powder to the die. Press at 20 tons for 0.3 minutes in a 3630 X-Press. *Anzelmo, John; Seyfarth, Alexander; and Arias, Larry (2001).
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
