方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
A small amount of an oligomeric hindered amine light stabilizer (HALS) (Adekastab LA-68LD) in polypropylene (PP) materials was directly determined by solid sampling matrix-assisted laser desorption/ionization mass spectrometry (MALDI-MS) using an internal standard method. First the matrix reagent (dithranol), 20 mg, and the empirically selected internal standard, angiotensin I (MW¼1296.5), 5 mg, were premixed in the solid state. The matrix mixture was then co-ground with the PP sample containing the HALS in liquid nitrogen using a freezer mill. The powdered sample mixture was spotted on the sample plate, suspended in ion-exchanged water, dried to adhere on the plate, and subjected to MALDI-MS. Three series of the HALS components accompanied by the oxidized species were clearly observed as their molecular ions (M.t) along with that of the internal standard in the mass spectra. A fairly good linear relationship (R2¼0.9991) with a relative standard deviation of ca. 11% was observed between the relative peak intensities of the HALS components and the HALS contents ranging from 0.1–2.5 wt%, which could be used as the calibration line to determine the HALS content in PP composites directly by MALDI-MS. The UV-exposed PP composite samples were evaluated by this method to interpret the photostabilizing action of HALS in the PP materials based on the observed change in the relative abundances of the original and oxidized HALS components as a function of UV-exposure time. Copyright # 2006 John Wiley & Sons, Ltd.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
