方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract This research is an effort to produce a useful polymer from a post-consumer mixed polymer waste stream consisting primarily of polypropylene and polyethylene. Mixed waste flakes were milled to a fine powder by cryogenic impact milling, and then injection molded into tensile test samples. The effect of incorporating nanoclay before milling was investigated. Despite the presence of porosity in the milled powder samples, the tensile properties were found to be higher than those of the unmilled polymer. Differential scanning calorimetry thermal analysis suggests the possibility of the formation of alloy between the immiscible polymers. q 2005 Elsevier Ltd. All rights reserved. Keywords : Plastic; Recycle; Nonoclay; Cryogenic milling; Tensile properties
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
