方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract The influence of cryogenic mechanical milling on the structure and the thermal behavior of isotactic polypropylene was investigated by means of wide-angle X-ray scattering, differential scanning calorimetry and transmission electron microscopy. The results presented show that structural changes caused by mechanical milling at cryogenic temperatures are only partly reversible. The decrease in the degree of crystallinity as determined by differential scanning calorimetry with increasing milling time is attributed to a reversible transformation of the initial morphology into a ‘‘nanostructured’’ morphology, consisting of small ‘‘fragments’’ of the original isotactic polypropylene lamellae. During recrystallization from the molten state, there still exists an influence of the previous milling treatment, leading to significantly changed crystallization behavior. The reason for this behavior might be a decrease in the molecular weight or a change in the molecular weight distribution or the formation of long-chain branched polypropylene molecules induced by cryogenic mechanical milling. Keywords Cryogenic mechanical milling Æ Polypropylene Æ Transmission electron microscopy Æ Nanostructure Æ Differential scanning calorimetry
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
