方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract Previous comparative studies on the impact of cryogenic mechanical milling (CMM) of polymers showed significantly changed thermal and mechanical properties and—in the case of some polymer blends (e.g., PMMA/PVDF) an improved miscibility. Those changes were mainly attributed to a reduction of the molecular weight average during the milling process. The crystallization process in macromolecular systems is strongly affected by any small change of the initial chain structure like the chain conformation, the presence of branches and of course a decrease of the molecular weight average. Therefore, the aim of this paperwas a comparative study of isothermal crystallization of cryogenic mechanically milled and original (unmilled) polymers and polymer blends. The overall crystal growth rates were determined and the development of the spherulitic morphology was studied in detail by means of hot stage polarized light microscopy. Isothermal crystallization of bulk samples was also investigated using differential scanning calorimetry (DSC). The average spherulite growth rates of the milled homo-polymer as well as the blends were significantly higher than in unmilled samples; even when all experiments started from the molten state. Moreover, the increase in crystal growth was almost independent of the chosen crystallization temperature and thus the degree of undercooling. © 2006 Elsevier B.V. All rights reserved. Keywords: Cryogenic mechanical milling; PVDF; Blends; Crystallization
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
