方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract A simple method combining slurry sampling after cryogenic grinding and the use of a permanent modification of the integrated platform inside the transversely heated graphite atomizer (THGA) was proposed for the determination of Cd and Pb in foods. Potentialities of the cryogenic grinding were evaluated for grinding different materials of difficult homogenization such as high fat and high fiber tissues. Animal and vegetal samples were cut into small pieces and ground in liquid nitrogen for 2 min. Slurries were prepared directly in the autosampler cup after cryogenic grinding by transferring an exact amount of homogeneous powdered material (5–20 mg) to the cup, followed by 1.00 mL of 0.2% (v/v) HNO3 containing 0.04% (v/v) Triton X-100 and sonication for 30 s, before transferring into the platform previously coated with 250 μg W and 200 μg Rh. Use of a tungsten carbide-rhodium permanent modifier combined with NH4H2PO4 conventional modifier improves tube lifetime and increases the pyrolysis temperature for Cd. Homogeneity tests, carried out by comparing the between- and within-batch precision for each kind of sample, showed no significant differences at the 95% confidence level, indicating good homogeneity for 5–20 mg masses. Detection limits were 3.3 ng g–1 Cd and 75 ng g–1 Pb for 1% m/v slurries. Results for determination of Cd and Pb in foods slurries were in agreement with those obtained with digested samples, since no statistical differences were found by the paired t-test at the 95% level.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
