方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract The mechanical alloying is the most convenient method to produce Mg–Ni alloys. In this study, the effect of ball-to-powder weight ratios and the mechanical alloying time on amorphization of Mg50Ni50 alloy and its thermal stabilities were investigated. Mg50Ni50 alloy has been produced by using Spex 8000 D mixer/mill with different ball-to-powder weight ratios (5:1, 10:1, 20:1). Amorphization times by XRD analysis are found to be 60 h for 5:1 ball-to-powder weight ratio, 10 h for 10:1 ball-to-powder weight ratio and 5 h for 20:1 ball-to-powder weight ratio. The thermal stabilities of amorphous Mg50Ni50 alloys, obtained by different ball-to-powder weight ratios, have been determined and the effect of heating rates on the crystallization temperatures have also been investigated by DSC. The heating rates employed were 5, 10, 15, 20 ◦C/min. During the first crystallization reaction, the amorphous and Mg2Ni intermetallic phases occurred. DSC studies show that increase in heating rates increased the crystallization temperatures for all samples. The apparent activation energies were determined by means of the Kissinger method. 2006 International Association for Hydrogen Energy. Published by Elsevier Ltd. All rights reserved. Keywords: Amorphous materials; Mechanical alloying; Hydrogen storage; Crystallization 1. Introduction Mechanical alloying is a solid-state powderprocessing technique that allows to synthesize materials by a high-energy ball milling. This method was first developed by Benjamin and co-workers in 1966 to produce oxide dispersion-strengthened alloys [1,2]. Mechanical alloying has been used to produce various materials such as oxide dispersion-strengthened alloys,
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
