方案下载应用领域 | |
检测样本 | |
检测项目 | |
参考标准 |
Abstract In the current study, pure elemental powders of Fe and S were mixed to give the desired compositions of Fe67S33, Fe50S50 and Fe33S67. A SPEX 8000D high-energy ball mill was used to synthesize iron sulfide powders under an Ar-filled atmosphere. The as-milled powders were examined by conventional X-ray diffraction (XRD) and synchrotron X-ray absorption spectroscopy (XAS). The experimental results showed that mechanochemical reactions occurred during the ball milling process for all the compositions investigated. The Fe1−xS phase was observed at the end of milling. The formation time of the Fe1−xS phase increased with increasing sulfur content. Extended X-ray absorption fine structure (EXAFS) results revealed that the nearest neighbor bond lengths of the radial distribution function for iron decreased when iron sulfides formed. X-ray absorption near-edge structure (XANES) of sulfar K-edges distinguished better the structural evolution of these iron sulfides. © 2003 Elsevier B.V. All rights reserved.
Hot consolidation of Cu–Li powder alloys
BioDrop 微量比色皿
BioDrop TOUCH 超微量分光光度计
BioDrop μLITE 超微量分光光度计
BioDrop DUO 多功能超微量分光光度计
高通量动植物组织研磨机
SpectroMill®-TS单研磨罐高能量球磨机
SpectroMill® II双研磨罐高能量球磨机
冷冻研磨系统
HT Mini高能量台式动植物组织研磨机
HT Homogenizer高通量动植物组织研磨机
Talboys 多点磁力搅拌器
Talboys 数显型5000敞开式摇床
Talboys Professional 3500恒温培养摇床
Talboys 数显型旋涡混合器
Talboys 数显型多管式旋涡混合器
