Hitachi High-Tech Developed
New HF5000 Field Emission Transmission Electron Microscope
- New 200kV transmission electron microscope provides sub-angstrom spatial resolution -
TOKYO, Japan, July 21, 2015 — Hitachi High-Technologies Corporation (TOKYO: 8036, Hitachi High-Tech) announced that it has developed the HF5000 field emission transmission electron microscope (FE-TEM) with a maximum 200kV accelerating voltage and standard equipped spherical aberration corrector.
The HF5000 is a new 200kV TEM combining Hitachi High-Tech's TEM and scanning transmission electron microscope (STEM) technologies to achieve spatial resolution at the sub-angstrom (Sub-Å, 0.1 nm or less) level. Its sales launch is scheduled for October, 2015.
In fields ranging from academic research of advanced nanomaterials and electronic devices to corporate R&D and quality control, there have been increased demands to improve both spatial imaging resolution and elemental analysis for electron microscopes. This, in turn, has given rise to the need to simultaneously achieve both aberration correction and high sensitivity analysis in microscopy. In response to this need, Hitachi High-Tech had developed 200kV dedicated STEM equipped with a spherical aberration corrector and large solid angle EDX*1, as well as 300kV TEM. In the meantime, Hitachi High-Tech has received feedback from many customers to integrate both electron microscopy technologies into a single 200kV TEM platform.
In response, Hitachi High-Tech has developed the HF5000 FE-TEM, equipped with a spherical aberration corrector, that simultaneously achieves both Sub-Å high-resolution imaging and high-sensitivity analysis on a single 200kV TEM platform.
The HF5000 inherits features from Hitachi High-Tech's HD-2700 dedicated STEM, such as its in-house spherical aberration corrector, automated aberration correction function, and atomic resolution SE*2 imaging, while incorporating the TEM technologies developed in the HF series. Furthermore, the HF5000 electron gun, based on Hitachi High-Tech's proven cold field-emission electron source technology, was thoroughly reviewed, and its column and specimen stage were redesigned to significantly enhance instrument performance and stability.
Integrating these electron microscopy technologies developed by Hitachi High-Tech into a new 200kV TEM enhanced platform brings together aberration correction and high-sensitivity analysis, with a wide variety of observation methods on the HF5000.
With the development of the new 200kV HF5000 FE-TEM, Hitachi High-Tech seeks to offer Sub-Å high-resolution imaging and high-sensitivity analysis, with its observation method versatility, to a broad range of users, including high-end users. Shipment of the HF5000 is scheduled to be in the second half of FY 2015.
Hitachi High-Tech will display a preview panel of the HF5000 at the commercial exhibition of Microscopy & Microanalysis 2015, to be held at the Oregon Convention Center in Portland, U.S.A, from Sunday, August 2 through Thursday, August 6, 2015.
*1 EDX: Energy Dispersive X-ray Spectroscopy
*2 SE: Secondary Electron
The HF5000 Field Emission Transmission Electron Microscope
Main Features
Standard equipped with a probe-forming spherical aberration corrector developed by Hitachi High-Tech (including automated aberration correction function)
Equipped with a highly-stabilized cold FE electron gun
Enhanced instrument performance achieved by highly-stabilized column and power supply
Aberration-corrected atomic resolution SE imaging
New side-entry specimen stage and specimen holder
Compatible with a dual configuration of large solid angle EDX*
Standard equipped with a TEM imaging camera
Newly designed enclosure cover
Lineup of special specimen holders, including 360° rotational holder* and air-protection holder*
Specimen holder compatible with Hitachi High-Tech's FIB*3 sample preparation tool
Option
Main Specifications
*3 FIB: Focused Ion Beam
*4 ADF-STEM: Annular Dark Field - STEM
会议邀约 | 相约2024中国国际光电博览会
日立高新发布TM4000系列台式显微镜:优化操作流程,确保高精度数据无差异获取
日立应用 | 光谱分析技术在纺织材料遮热性能表征中的应用
日立应用 | 塑料薄膜添加剂粉体的粒径统计及三维形态测量
