Abstract
The Solanaceae plant family contains at least 98 genera and over 2700 species. The Duboisia genus stands out for its ability to produce pyridine and tropane alkaloids, which are relatively poorly characterized at the phytochemical level. In this study, we analyzed dried leaves of Duboisia spp. using supercritical CO2 extraction and ultra-high-pressure liquid chromatography coupled to high-resolution tandem mass spectrometry, followed by feature-based molecular networking. Thirty-one known tropane alkaloids were putatively annotated, and the identity of six (atropine, scopolamine, anisodamine, aposcopolamine, apoatropine, and noratropine) were identified using reference standards. Two new granatane alkaloids connected in the molecular network were highlighted from Duboisia myoporoides, and their α-granatane tropate and α-granatane isovalerate structures were unambiguously established by semisynthesis.
茄科植物至少有98属2700多种。Duboisia属因其产生吡啶和莨菪烷生物碱的能力而脱颖而出,这些生物碱在植物化学水平上的特征相对较差。在这项研究中,我们使用超临界CO2萃取和超高压液相色谱结合高分辨率串联质谱,然后基于特征的分子网络分析了杜波锡属植物的干叶。假定对31种已知的托烷生物碱进行了注释,并使用参考标准鉴定了6种(阿托品、东莨菪碱、山莨菪碱、阿托品碱、阿托品碱和去甲托品碱)的身份。从Duboisia myoroides中突出了分子网络中连接的两种新的石榴烷生物碱,并通过半合成明确地建立了它们的α-石榴烷营养盐和α-石榴坦异戊酸盐结构。
超临界流体从葡萄渣中连续提取高附加值分子
苹果果实性状和采后条件对单核细胞增生李斯特菌存活的影响
动态控制气调技术有助于减少梨果采后病害
SCS动态气调保鲜技术用于药用大麻干燥、固化
