方案下载应用领域 | 地矿 |
检测样本 | 非金属矿产 |
检测项目 | 痕量元素 |
参考标准 | - |
The determination of different mineral phases through backscattered electron (BSE) detectors is a common task in mineralogy. This approach however has limitations. If minerals with different composition but similar average atomic number are viewed with a BSE detector there is very little if no material contrast to be observed. This shortfall can be overcome through use of X-ray elemental maps. The innovative XFlash® 4010 SDD allows extremely high input and output count rates, hence elemental maps can be performed in about one tenth of the time required by conventional Si(Li) detectors.
Results show that EDS maps have an advantage over BSE
images: latter fail to distinguish some mineral phases due
to their similar average atomic number contrast. The maps
permit to discriminate the minerals quartz [SiO2], dolomite
[(Ca,Mg)CO3] and sodium feldspar [NaAlSi3O8] as well as
calcite [CaCO3] and potassium feldspar [KAlSi3O8] – and so
display a wealth of data that electron images simply cannot
provide.
双相不锈钢的增强纳米压痕应用
EBSD和EDS在矿物学样品的相识别和分布应用
原位压缩和拉伸变形材料的定向对比成像和EBSD分析
布鲁克扫描电镜专用原位纳米力学测试系统PI 88
布鲁克3D EDS/EBSD重构软件QUBE
布鲁克 ESPRIT 四合一分析软件
布鲁克 QUANTAX WDS波谱仪
布鲁克 QUANTAX 微区荧光光谱仪
布鲁克 平插式能谱仪FlatQUAD
布鲁克 电子背散射衍射仪 EBSD eflash FS
布鲁克 电子背散射衍射仪 EBSD
布鲁克 电子背散射衍射仪 EBSD
布鲁克 QUANTAX EDS 能谱仪(TEM)
布鲁克 , EDS, 能谱仪, SEM, TEM
TXRF全反射X射线荧光光谱仪S4 TSTAR
TXRF全反射X射线荧光光谱仪S2 PICOFOX
便携式/手持式X射线荧光光谱仪
便携式/手持式X射线荧光光谱仪
