方案下载应用领域 | 公安/司法 |
检测样本 | 刑侦 |
检测项目 | 元素分析 |
参考标准 | - |
Using an automated scanning electron microscope (SEM) and energy dispersive X-ray spectroscopy (EDS) to find and positively identify gunshot residue (GSR), has been an accepted method for forensic applications for quite a number of years.
has been demonstrated that due to the spatial resolution
of EDS, it would be favorable to use 15 kV acceleration
voltage instead of 25 kV for GSR analysis. It has also been
shown that the results of low count spectra of real GSR
particles yield similar results when using 15 kV compared
to 25 kV. High count spectra also show comparable results
for these particles. However, the differences in 25 kV and
15 kV can be attributed to the structure of the particles,
such as flat, hollow or small particles affecting results.
Furthermore, the inhomogeneous nature of GSR particles
adds to the complexity of result interpretation. The much
larger excitation volume when analyzing with 25 kV can
skew results of these particles even further.
Also, it has been shown, that when using a bulk sample
or standard with a known concentration, the new Opti-
Series-Fit Deconvolution and the standardless PB-ZAF
quantification in conjunction with a high resolution XFlash®
Detector, can in fact produce very reliable results at 15 kV,
matching the certified values.
双相不锈钢的增强纳米压痕应用
EBSD和EDS在矿物学样品的相识别和分布应用
原位压缩和拉伸变形材料的定向对比成像和EBSD分析
布鲁克扫描电镜专用原位纳米力学测试系统PI 88
布鲁克3D EDS/EBSD重构软件QUBE
布鲁克 ESPRIT 四合一分析软件
布鲁克 QUANTAX WDS波谱仪
布鲁克 QUANTAX 微区荧光光谱仪
布鲁克 平插式能谱仪FlatQUAD
布鲁克 电子背散射衍射仪 EBSD eflash FS
布鲁克 电子背散射衍射仪 EBSD
布鲁克 电子背散射衍射仪 EBSD
布鲁克 QUANTAX EDS 能谱仪(TEM)
布鲁克 , EDS, 能谱仪, SEM, TEM
TXRF全反射X射线荧光光谱仪S4 TSTAR
TXRF全反射X射线荧光光谱仪S2 PICOFOX
便携式/手持式X射线荧光光谱仪
便携式/手持式X射线荧光光谱仪
