Rabbit Anti-Oct2 antibody
Catalog Number :RS-05017R
Quantity size : 0.1ml (dilute with pH 7.4 0.01 M PBS or antibody diluent )
background:
The protein encoded by this gene is a homeobox-containing transcription factor of the POU domain family. The encoded protein binds the octamer sequence 5'-ATTTGCAT-3', a common transcription factor binding site in immunoglobulin gene promoters. Several transcript variants encoding different isoforms have been found for this gene. [provided by RefSeq, Oct 2011].
Specificity :
–Anti-Oct2 is a rabbit polyclonal antibody
–specific for anti-Oct2 of human,rat,mo
– use for western blotting,elisa,immunoprecipitation and immunohistochemistry
–Protein G affinity chromatography purification, purity :>95%
– Isotype: IgG
– mol wt: 58 kDa
Application :
– WB=1:100-500
– ELISA=1:500-1000
– IHC-P=1:100-500
– IHC-F=1:100-500
– IF=1:50-200
– not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user..
Storage: Store at -20℃ for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20℃. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody, the antibody is stable for at least six weeks at 2-4 ℃
Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
上海瑞齐ELISA试剂盒特惠
TRAF2抗体说明书
Anti-Snail 1抗体
SOD做预实验时,有几种方法?
黑色素瘤相关抗原/黑色素-A抗体,MelanA抗体
神经丝蛋白抗体
维生素K依赖的蛋白C重链抗体,protein C抗体
早老素蛋白-1抗体,presenilin 1抗体蛋白质磷酸酶-2A抗体,PP2A alpha + beta抗体
骨桥蛋白抗体,osteopontin抗体
骨桥蛋白/分泌型磷蛋白1抗体osteopontin抗体
巢蛋白/神经上皮干细胞蛋白抗体,Nestin抗体
心脏肌球蛋白结合蛋白抗体MYBPC3抗体
HPR抗体,结合珠蛋白相关蛋白抗体
Anti-PRL抗体-鼠抗人泌乳素抗体(一抗)
Anti-LH抗体-鼠抗人促黄体生成素抗体(一抗)
Anti-β-HCG抗体(一抗)
